Выберете то, что вам нужно
  1. Sony Xperia XA Loudspeaker Replacement, Back Cover: step 1, image 1 of 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Loudspeaker Replacement: step 2, image 1 of 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Loudspeaker Replacement: step 3, image 1 of 3 Sony Xperia XA Loudspeaker Replacement: step 3, image 2 of 3 Sony Xperia XA Loudspeaker Replacement: step 3, image 3 of 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Loudspeaker Replacement: step 4, image 1 of 3 Sony Xperia XA Loudspeaker Replacement: step 4, image 2 of 3 Sony Xperia XA Loudspeaker Replacement: step 4, image 3 of 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Loudspeaker Replacement: step 5, image 1 of 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Loudspeaker Replacement: step 6, image 1 of 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Loudspeaker Replacement, Loudspeaker: step 7, image 1 of 2 Sony Xperia XA Loudspeaker Replacement, Loudspeaker: step 7, image 2 of 2
    • Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
  8. Sony Xperia XA Loudspeaker Replacement: step 8, image 1 of 2 Sony Xperia XA Loudspeaker Replacement: step 8, image 2 of 2
    • Push back the two retaining tabs on the top of the loudspeaker with the spudger.
  9. Sony Xperia XA Loudspeaker Replacement: step 9, image 1 of 1
    • Pry the loudspeaker up with the spudger.
  10. Sony Xperia XA Loudspeaker Replacement: step 10, image 1 of 1
    • Remove the loudspeaker with your hands.
Заключение
2 участников успешно повторили данное руководство.
Stephen Rock
Участник с: 18.04.2018
230 Репутация
Автор 2 руководств
Cal Poly, Team S17-G2, Livingston Spring 2018 Участник Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 членов
Автор 8 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 427
