Sony Xperia XA2 Ultra Charging Port Replacement
Выберете то, что вам нужно
  1. Sony Xperia XA2 Ultra Charging Port Replacement, Rear Cover: шаг 1, изображение 1 из 2 Sony Xperia XA2 Ultra Charging Port Replacement, Rear Cover: шаг 1, изображение 2 из 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 2, изображение 1 из 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 3, изображение 1 из 2 Sony Xperia XA2 Ultra Charging Port Replacement: шаг 3, изображение 2 из 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 4, изображение 1 из 2 Sony Xperia XA2 Ultra Charging Port Replacement: шаг 4, изображение 2 из 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 5, изображение 1 из 2 Sony Xperia XA2 Ultra Charging Port Replacement: шаг 5, изображение 2 из 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 6, изображение 1 из 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Charging Port Replacement, Speaker: шаг 7, изображение 1 из 2 Sony Xperia XA2 Ultra Charging Port Replacement, Speaker: шаг 7, изображение 2 из 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  8. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 8, изображение 1 из 2 Sony Xperia XA2 Ultra Charging Port Replacement: шаг 8, изображение 2 из 2
    • Using an iFixit opening tool, pry and remove the speaker.
  9. Sony Xperia XA2 Ultra Charging Port Replacement, Charging Port: шаг 9, изображение 1 из 1
    • Using the iFixit opening tool, disconnect the flex cable.
  10. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 10, изображение 1 из 2 Sony Xperia XA2 Ultra Charging Port Replacement: шаг 10, изображение 2 из 2
    • Remove both the black and white antenna cables using the Jimmy.
  11. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 11, изображение 1 из 1
    • Remove the vibration flex cable with the Jimmy.
  12. Sony Xperia XA2 Ultra Charging Port Replacement: шаг 12, изображение 1 из 1
    • Using the Jimmy and the iFixit opening tool, remove the charging port.
Заключение
Alyssa Bayles
Участник с: 09/27/22
819 Репутация
Автор 8 руководств
Команда
Utah Tech University, Team 1-1, Randazzo Fall 2023 Участник Utah Tech University, Team 1-1, Randazzo Fall 2023
UTAHTECH-RANDAZZO-F23S1G1
1 член
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 179
