Введение
If your phone is running slow or looses charge very quickly, your battery might be the reason and it may be time for a replacement. This guide will instruct you on replacing the battery of your Sony Xperia XZ2.
Before removing the battery, you will have to remove the front screen. You will need a spudger and a Phillips #00 screwdriver head.
Выберете то, что вам нужно
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
3 участников успешно повторили данное руководство.
