Введение
If the rear camera of your phone is cracked or not functioning correctly, it may be time for a replacement. This guide will walk you through replacing the rear camera on your Sony Xperia XZ2.
For this guide you will need a hair dryer, opening picks, angled tweezers, a spudger, and a Phillips #00 screwdriver.
Выберете то, что вам нужно
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
Take out the one 3mm screw on the motherboard with the Phillips #00 screwdriver.
Disconnect the yellow connector by gently prying both sides of it using a spudger.
Disconnect the camera module from the motherboard by pulling the module up from the side using a spudger.
2 участников успешно повторили данное руководство.
