Введение
If you need to replace the vibration motor on your phone use this guide. The vibration motor is what vibrates your phone every time you get a notification. If your phone is not vibrating when it should be, you may need to replace the vibration motor. For this guide you will need a spudger. To replace the vibration motor you first need to remove the LCD screen and the battery, which can be moderately difficult.
Выберете то, что вам нужно
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
Remove the two 3.5mm head screws with a Phillips #00 screwdriver.
Remove the vibration flex connector by inserting a spudger into the socket and gently prying off the connector.
Еще один человек закончил это руководство.
