Sony Xperia Z Ultra Battery Replacement
Выберете то, что вам нужно
  1. Sony Xperia Z Ultra Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Use the small suction cup to lift the back panel:
    • Press the small suction cup on to the middle of the back panel.
  2. Sony Xperia Z Ultra Battery Replacement: шаг 2, изображение 1 из 1
    • While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
    • While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
    • Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
  3. Sony Xperia Z Ultra Battery Replacement: шаг 3, изображение 1 из 1
    • Remove the back panel by pulling the small suction cup upwards.
  4. Sony Xperia Z Ultra Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the following six screws with a Phillips #000 screwdriver:
    • five silver 2.1 mm screws
    • one gold 3.1 mm screw
  5. Sony Xperia Z Ultra Battery Replacement: шаг 5, изображение 1 из 1
    • Pry the plastic motherboard shield open by placing the spudger under the shield and running it along the edges.
  6. Sony Xperia Z Ultra Battery Replacement: шаг 6, изображение 1 из 1
    • Use care to remove the motherboard shield, as it may break. The motherboard shield is made of a very thin plastic.
    • Remove the motherboard shield by lifting the lower end upwards first.
  7. Sony Xperia Z Ultra Battery Replacement: шаг 7, изображение 1 из 2 Sony Xperia Z Ultra Battery Replacement: шаг 7, изображение 2 из 2
    • Detach the battery connection cable by prying it upward with the spudger.
  8. Sony Xperia Z Ultra Battery Replacement: шаг 8, изображение 1 из 1
    • Pry the upper end of the antenna upwards with the spudger.
  9. Sony Xperia Z Ultra Battery Replacement: шаг 9, изображение 1 из 1
    • Detach the antenna by pulling the upper end upwards and outwards.
  10. Sony Xperia Z Ultra Battery Replacement: шаг 10, изображение 1 из 1
    • Insert the spudger underneath the battery and run it back and forth to remove any adhesive.
  11. Sony Xperia Z Ultra Battery Replacement: шаг 11, изображение 1 из 1
    • Remove the battery from the phone.
Заключение
16 участников успешно повторили данное руководство.
Carlos
Участник с: 10/01/15
222 Репутация
1 руководство автора
Команда
Cal Poly, Team 4-6, Maness Fall 2015 Участник Cal Poly, Team 4-6, Maness Fall 2015
CPSU-MANESS-F15S4G6
4 членов
Автор 10 руководств
5 Комментариев
Does this fix change the waterproof efficiency?
atilasilva - Ответить
Hello atilasilva,
I guess so. Since you have to either replace the complete back cover or at least the glue line around the back cover I think the phone will not be completely waterproof again. It still may be solid splash proof.
Sven Decker -
Thanks a lot. This instruction really helped me to replace the battery!
Kirill - Ответить
I am about to follow your procedures to do a battery replacement. I have read your instructions, one question is if any need to use some glues to fix the back panel of the Sony Phone? From your instruction you did not mention the use of any glue at all, I am a bit concerned because at the moment my Sony phone both front and back panes are already loosen. I was told this is due to the old battery expanding.
Thanks for your help
David444 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 48
За всё время: 18,981
