Введение
If your screen went black while using the front camera and performing a hard reset and software update did not fix this problem, replacing the front camera may solve these problems.
Выберете то, что вам нужно
Use the small suction cup to lift the back panel:
Press the small suction cup on to the middle of the back panel.
While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
Remove the following six screws with a Phillips #000 screwdriver:
five silver 2.1 mm screws
one gold 3.1 mm screw
Pry the plastic motherboard shield open by placing the spudger under the shield and running it along the edges.
Insert the spudger underneath the battery and run it back and forth to remove any adhesive.
Pry the connection upwards from the motherboard with the spudger to reveal the front facing camera.
4 участников успешно повторили данное руководство.
