Введение
After Android version 4.2 you can't reset password from the service / test menu because the developers closed this door. Now the only way is with changing the firmware.
PC Companion will install the latest firmware on your phone and will reset it to the Factory setting.
You can use this technique also if your device is not boot properly.
!!! This will erase all your personal data!!!
If your device is connected to the internet and you have an installed Google account on it, look at this manual:
Android Device Manager - Bypass Screen Lock on any Android Device
Please SUBSCRIBE to my channel ツ
Video Overview
  1. Download and install Sony PC Companion. Sony PC Companion Sony PC Companion
  2. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  3. From here you can update your device firmware but it must be unlocked (device can't be in lock screen). Start the new PC Companion function "Support Zone". PC Companion will download some necessary files and you are ready to start "Phone / Tablet Software Update".
    • From here you can update your device firmware but it must be unlocked (device can't be in lock screen).
    • Start the new PC Companion function "Support Zone".
    • PC Companion will download some necessary files and you are ready to start "Phone / Tablet Software Update".
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Your laptop must be connected to the power adapter. Select "repair my phone / tablet". The last warning for your personal data
    • Your laptop must be connected to the power adapter.
    • Select "repair my phone / tablet".
    • The last warning for your personal data
  6. After PC Companion prepared your laptop for the update, you must choose the model of your device. The battery must be at last 80% charged. Doesn't make a mistake in choosing the model.
    • After PC Companion prepared your laptop for the update, you must choose the model of your device.
    • The battery must be at last 80% charged.
    • Doesn't make a mistake in choosing the model.
  7. Switch of the phone. If you have a problem with the Android OS and you can't switch it off, then press and hold the power on button for a long time, or use the reset button under the micro SIM cover. Press and hold the volume down button and then insert the micro USB cable. Your PC will recognize the phone and PC Companion will download the latest version for your device and will flash it.
    • Switch of the phone. If you have a problem with the Android OS and you can't switch it off, then press and hold the power on button for a long time, or use the reset button under the micro SIM cover.
    • Press and hold the volume down button and then insert the micro USB cable.
    • Your PC will recognize the phone and PC Companion will download the latest version for your device and will flash it.
  8. If your PC doesn't recognize you phone (SOMC Flash Device), you must install drivers for it. S1Boot Fasboot drivers S1Boot Fasboot drivers
    • If your PC doesn't recognize you phone (SOMC Flash Device), you must install drivers for it.
    • S1Boot Fasboot drivers
  9. When PC Companion finished updating, disconnect the phone and switch it on. Your device is with latest firmware, in factory state, without personal data and security. .
    • When PC Companion finished updating, disconnect the phone and switch it on.
    • Your device is with latest firmware, in factory state, without personal data and security.
    • Please SUBSCRIBE to my channel ツ
Заключение
18 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
163 044 Репутация
Автор 304 руководств
Команда
Master Techs Member of Master Techs
Community
281 членов
Автор 792 руководств
Один комментарий
Thank you, this was really helpful.
DOWNLOAD AND UPDATE FIRMWARE SONY XPERIA XZ 601SO gofirmware
Jacky888 Jacky888 - Ответить
Просмотр статистики:
За 24 часа: 5
За 7 дней: 27
За 30 дней: 112
За всё время: 19,596
