Введение
A faulty battery may lead to short battery life on a single charge or your Sony Xperia Z1 losing power even when high battery percentage indications are shown. Replacing the battery will aid in increasing the time available for using your device and will contribute to the overall better functioning of the phone.
Выберете то, что вам нужно
With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
Apply a suction cup tool to the center of the back panel and gently pull the panel off the back of the phone.
If you are experiencing difficulty, use an opening pick to slide into the crack in between the panel and the rest of the phone body to pry off the back.
Use the Torx T5 screwdriver to remove the two 3.81mm screws from the corners of the battery.
Use the plastic opening tool to gently pry off the two flex connectors from the motherboard. Getting access to one of the connectors requires prying off the other first, so be sure to remove the top connector first.
Slowly slip the halberd spudger underneath the rest of the orange flex cable to carefully peel the adhesive portion away from the rest of the phone.
Use the tweezers to grab the top right corner of battery and carefully lift it up and away from the phone.
Once the battery is at a safe enough height, grip the corner of the battery and slowly pull it out of the phone.
