Sony Xperia Z1 Charging Port Replacement
Выберете то, что вам нужно
  1. Sony Xperia Z1 Charging Port Replacement, Battery: шаг 1, изображение 1 из 1
    • Before you begin, use caution while handling a heat gun.
    • With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
  2. Sony Xperia Z1 Charging Port Replacement: шаг 2, изображение 1 из 2 Sony Xperia Z1 Charging Port Replacement: шаг 2, изображение 2 из 2
    • Apply a suction cup tool to the center of the back panel and gently pull the panel off the back of the phone.
    • If you are experiencing difficulty, use an opening pick to slide into the crack in between the panel and the rest of the phone body to pry off the back.
  3. Sony Xperia Z1 Charging Port Replacement: шаг 3, изображение 1 из 2 Sony Xperia Z1 Charging Port Replacement: шаг 3, изображение 2 из 2
    • Use the Torx T5 screwdriver to remove the two 3.81mm screws from the corners of the battery.
  4. Sony Xperia Z1 Charging Port Replacement: шаг 4, изображение 1 из 2 Sony Xperia Z1 Charging Port Replacement: шаг 4, изображение 2 из 2
    • Use the plastic opening tool to gently pry off the two flex connectors from the motherboard. Getting access to one of the connectors requires prying off the other first, so be sure to remove the top connector first.
    • Tip: you may need to use the tweezers to gently hold the top connector out of the way while prying off the bottom connector.
  5. Sony Xperia Z1 Charging Port Replacement: шаг 5, изображение 1 из 1
    • Slowly slip the halberd spudger underneath the rest of the orange flex cable to carefully peel the adhesive portion away from the rest of the phone.
  6. Sony Xperia Z1 Charging Port Replacement: шаг 6, изображение 1 из 1
    • Use the tweezers to grab the top right corner of battery and carefully lift it up and away from the phone.
  7. Sony Xperia Z1 Charging Port Replacement: шаг 7, изображение 1 из 1
    • Once the battery is at a safe enough height, grip the corner of the battery and slowly pull it out of the phone.
    • The old battery can be recycled at any local office supply store that supports recycling used batteries.
  8. Sony Xperia Z1 Charging Port Replacement, Charging Port: шаг 8, изображение 1 из 3 Sony Xperia Z1 Charging Port Replacement, Charging Port: шаг 8, изображение 2 из 3 Sony Xperia Z1 Charging Port Replacement, Charging Port: шаг 8, изображение 3 из 3
    • Use a T5 Torx screwdriver to remove the two screws on the long metal bracket along the left side of the phone.
    • Remove the metal cover with a pair of tweezers.
  9. Sony Xperia Z1 Charging Port Replacement: шаг 9, изображение 1 из 1
    • Use a pair of tweezers to remove the plastic cover above the speakers.
  10. Sony Xperia Z1 Charging Port Replacement: шаг 10, изображение 1 из 1
    • Use a plastic opening tool to remove the coaxial cable from the bottom of the motherboard by prying it upward.
  11. Sony Xperia Z1 Charging Port Replacement: шаг 11, изображение 1 из 1
    • Using the plastic opening tool, remove the press fit connector attached to the motherboard.
  12. Sony Xperia Z1 Charging Port Replacement: шаг 12, изображение 1 из 1
    • Using the plastic opening tool, remove the press fit connector attached to the motherboard in the upper righthand corner.
  13. Sony Xperia Z1 Charging Port Replacement: шаг 13, изображение 1 из 2 Sony Xperia Z1 Charging Port Replacement: шаг 13, изображение 2 из 2
    • Using the plastic opening tool, remove the press fit camera connector from the motherboard.
    • Lift the camera out from the motherboard.
  14. Sony Xperia Z1 Charging Port Replacement: шаг 14, изображение 1 из 3 Sony Xperia Z1 Charging Port Replacement: шаг 14, изображение 2 из 3 Sony Xperia Z1 Charging Port Replacement: шаг 14, изображение 3 из 3
    • Using a plastic spudger, lift the motherboard upwards in order to separate it from the phone.
    • The images depict a metal spudger being used, which poses a potential to damage the motherboard. We recommend using an ESD-safe tool instead.
    • As the motherboard is lifted up, grab it with a pair of tweezers and lift it out of the phone.
  15. Sony Xperia Z1 Charging Port Replacement: шаг 15, изображение 1 из 2 Sony Xperia Z1 Charging Port Replacement: шаг 15, изображение 2 из 2
    • Grab your Soldering Iron and heat it up. Once it is at around 200° F, apply pressure to the soldering pads on the left and right side of the connector. In order to replace the charging port, grab your connector and solder it back onto the same soldering pads.
Заключение
Еще один человек закончил это руководство.
Harrison Vance
Участник с: 02/03/20
245 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 34
За всё время: 1,452
