Введение
This guide will demonstrate how to replace the Sony Xperia Z1 rear camera and secure the rear camera connections which may be causing issues when capturing pictures.
Выберете то, что вам нужно
With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
Apply a suction cup tool to the center of the back panel and gently pull the panel off the back of the phone.
Using the plastic opening tool, carefully pry off the flex connector beside the camera housing.
