Введение
How to disassemble the phone and replace the Display Assembly (LCD Display & Touchscreen module).
Выберете то, что вам нужно
Видео обзор
Switch off the phone.
If you can't switch it off, you can use the OFF button near to the SIM card Tray.
Warm the Back Cover. You can use a hairdryer.
Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
Disconnect the Battery Flex Cable and remove the two Philips screws.
Li-Polymer Battery, 3.8V, 3200mAh
Part number: LIS1543ERPC
Remove the Loudspeaker metal bracket.
Remove the two Phillips screws that hold Loudspeaker/Vibromotor module.
Disconnect the Coaxial Antenna cable.
With the sharp end of the plastic tool carefully subtract the module from the phone housing.
The Loud Speaker has some adhesive holding it to the chassis so a little heat on the front will help.
Use a transparent packaging tape and stick it on top of the glass. This will help you remove the broken glass later.
Preheat the Display.
Use a cutter to make a room for a plastic tool.
Clean the frame from the remains of tape.
Now it's time to test the new spare part.
Use a high quality adhesive sticker for the model.
This will stick the display to the frame harder and it will save the waterproof ability of your phone.
Use again adhesive sticker to atach the back / battery cover.
All's well that ends well.
61 участников успешно повторили данное руководство.
22 Комментариев
Worked! I very much recommend watching the video as well as read the manual to get a complete picture. My total time spent was multiple hours, but largely because it's the first time I'm doing a repair that involves so much glue. Gained a few gray hairs there.
Two stumbles:
I missed the line "The load Speaker has some adhesive holding it to the chassis so a little heat on the front will help.", which cost me a lot of time and worry as I was trying to force the speaker assembly out. Eventually got it out, and it's fine. Ribbon cables will be the death of me some day.
I did not keep the little bit of tape on the display ribbon safe and clean and ended up not using it at all. The written manual doesn't show its reuse, the video does.
Also: getting (almost) all of the glue goop off the back was a tragedy.
so cool, is simple.
My Xperia Z2 touch screen is fixed at a phone repaircenter. I dont know what they do but since that day it looks like my touchscreen living his own life. Especially if i type some text with the stock keyboard. Its very frustrating and my question is.....can i do something about it myself?
Sorry for my bad English btw
Before gluing the screen to work well sensors and all that, you need to put some black tape on the camera or sensors?
Is it and seen online tutorials or is not necessary
