Введение
How to disassemble the phone and replace the Loudspeaker.
Please SUBSCRIBE to my channel ツ
Video Overview
  1. Switch off the phone. If you can't switch it off, you can use the OFF button near to the SIM card Tray. Warm the Back Cover. You can use a hairdryer.
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Use a small suction cup and plastic tools for separating the Rear panel. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  4. Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape). Please SUBSCRIBE to my channel  ツ
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
    • Please SUBSCRIBE to my channel ツ
  5. Disconnect the Battery Flex Cable and remove the two Philips screws. Li-Polymer Battery, 3.8V, 3200mAh Part number: LIS1543ERPC
  6. Remove the Loudspeaker metal bracket. Remove the Loudspeaker metal bracket. Remove the Loudspeaker metal bracket.
    • Remove the Loudspeaker metal bracket.
  7. Part of the Volume/PowerON/Mic flex cable is affixed onto the Loudspeaker/Vibro motor module. Under the Flex cable is the Loudspeaker. You can change only the Loudspeaker or or the Loudspeaker & Holder module.
    • Part of the Volume/PowerON/Mic flex cable is affixed onto the Loudspeaker/Vibro motor module.
    • Under the Flex cable is the Loudspeaker.
    • You can change only the Loudspeaker or or the Loudspeaker & Holder module.
    • Loudspeaker & Holder module Part No: 1282-2013
Заключение
4 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
165 854 Репутация
Автор 305 руководств
Команда
Master Techs Member of Master Techs
Community
287 членов
Автор 815 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 9
За 30 дней: 33
За всё время: 8,199
