Введение
Use this guide to replace the back cover of your Sony Z3.
Запчасти
Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
Lift up the back cover with a suction handle and put an opening pick in the gap.
Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
When the edges of the cover are free from adhesive, tilt it to allow access to the battery tabs.
Use tweezers to pull the two black adhesive strips out of the phone but don't pull just yet.
Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover.
5 участников успешно повторили данное руководство.
