Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
  1. Этот шаг не переведен. Помогите перевести
    Heat the back cover of your Xperia Z3 Compact with an iOpener to loosen the adhesive underneath. Lift up the back cover with a suction handle and put an opening pick in the gap. Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
    • Heat the back cover of your Xperia Z3 Compact with an iOpener to loosen the adhesive underneath.
    • Lift up the back cover with a suction handle and put an opening pick in the gap.
    • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
    • Now you can pull up the back cover with the suction handle.
  2. Этот шаг не переведен. Помогите перевести
    Use a tweezer to remove the model label which is hooked in the right side of the frame. Undo the flex cable of the NFC antenna with a tweezer.
    • Use a tweezer to remove the model label which is hooked in the right side of the frame.
    • Undo the flex cable of the NFC antenna with a tweezer.
  3. Этот шаг не переведен. Помогите перевести
    Unscrew the following screws which hold down the mid frame of the Sony Xperia Z3 Compact. Two 2.7 mm Phillips #000
    • Unscrew the following screws which hold down the mid frame of the Sony Xperia Z3 Compact.
    • Two 2.7 mm Phillips #000
    • Three 2.5 mm Phillips #000
    • Use a Spudger to lift up the mid frame on each side.
    • Be careful and patient, the plastic mid frame is fragile and might break if bent too hard.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Этот шаг не переведен. Помогите перевести
    Declamp the metal bracket which holds down the flex connector of the rear camera. Unplug the flex connector of the rear camera and lift it out of its recess. Unplug the flex connector of the rear camera and lift it out of its recess.
    • Declamp the metal bracket which holds down the flex connector of the rear camera.
    • Unplug the flex connector of the rear camera and lift it out of its recess.
  6. Этот шаг не переведен. Помогите перевести
    Use a Spudger to unplug the headphone jack and sensor cable connector. Unscrew the single 2.5 mm Phillips #000  screw on the upper left side of the motherboard.
    • Use a Spudger to unplug the headphone jack and sensor cable connector.
    • Unscrew the single 2.5 mm Phillips #000 screw on the upper left side of the motherboard.
  7. Этот шаг не переведен. Помогите перевести
    Unplug the battery and display flex connectors. Open the compartments for the SIM card and the micro SD card and remove them. Open the compartments for the SIM card and the micro SD card and remove them.
    • Unplug the battery and display flex connectors.
    • Open the compartments for the SIM card and the micro SD card and remove them.
  8. Этот шаг не переведен. Помогите перевести
    Use a Spudger to slightly lift up the motherboard. Be careful! You need to thread the display flex cable through a gap in the motherboard while lifting it up. It is also connected to the vibration motor, which still sticks to the phone. Take especially care of the two black connectors on the side of the battery. They break off easily during the removal of the motherboard.
    • Use a Spudger to slightly lift up the motherboard.
    • Be careful! You need to thread the display flex cable through a gap in the motherboard while lifting it up. It is also connected to the vibration motor, which still sticks to the phone.
    • Take especially care of the two black connectors on the side of the battery. They break off easily during the removal of the motherboard.
    • Use a tweezer to take out the vibration motor and then remove the motherboard completely.
  9. Этот шаг не переведен. Помогите перевести
    Gently pull out both of the black straps with the adhesive tabs underneath the battery. Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs. In this case use a plastic card to pry off the battery carefully,Use a little bit of heat if necessary! Now you can remove the battery from the motherboard easily.
    • Gently pull out both of the black straps with the adhesive tabs underneath the battery.
    • Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs. In this case use a plastic card to pry off the battery carefully,Use a little bit of heat if necessary!
    • Now you can remove the battery from the motherboard easily.
  10. Этот шаг не переведен. Помогите перевести
    Warm up the NFC antenna a little bit to loosen the adhesive underneath. Carefully peel it off the battery. If the adhesive starts to crumble use a plastic card  to loosen the adhesive. Carefully peel it off the battery. If the adhesive starts to crumble use a plastic card  to loosen the adhesive.
    • Warm up the NFC antenna a little bit to loosen the adhesive underneath.
    • Carefully peel it off the battery. If the adhesive starts to crumble use a plastic card to loosen the adhesive.
Финишная черта
19 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 31.03.2014
69 460 Репутация
Автор 134 руководств
Команда
iFixit Участник iFixit
Community
123 членов
Автор 11 785 руководств
Комментариев: 10
Thank you Tobias !
My Z3 compact starts now his second life :)
Guy Hard - Ответить
Thank you for repairing your phone and giving it a second chance.
Tobias Isakeit -
Where do I need the Back Cover Adhesive Strips for?
Visser - Ответить
The guide doesn’t mention that one needs new adhesive for the battery (the one I bought isn’t sold with it). It would therefore be wise to mention what kind of adhesive (two-sided, what thckness, etc.)
axel - Ответить
Double sided tape is enough to keep it in place, as the back cover and midframe holds everything down for extra reinforcement. Sony sure makes their smartphones !&&* to repair, but that’s another rant.
William Nephew -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 57
За последние 30 дней: 319
За всё время: 32,089
