Введение
This guide shows you how easy to replace Sony Xperia Z3 back cover. And if the phone waterproof or not depends not only perfect operation but also the good back cover replacement parts.
Выберете то, что вам нужно
Видео обзор
Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
Insert guitar pick into the gap and slide to cut the sticker around the back cover.
Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
Remove the back cover easily. It comes with camera lens and NFC.
And you can place your new back cover, press the adhesive sticker and done the replacement.
12 участников успешно повторили данное руководство.
2 Комментариев
My Xperia z3 was broken back cover if I replace this cover, this waterproof features are still working or not? guys I need your suggestions
