Введение
Sony Xperia Z3 battery is non-removable. When you encountered the problem with battery, it's a little complex to replace.
Инструменты
Запчасти
Видео обзор
Heat the back cover to soften the adhesive sticker.
Use the suction cup to open a gap from top side or bottom side.
Insert into the guitar pick and slide to cut the sticker.
Remove the back cover.
Pry up with a little effort because there is adhesive under the battery though not so strong.
That's Sony Xperia Z3 Dual 3100mAh battery.
When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
11 участников успешно повторили данное руководство.
Комментариев: 2
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Just finished this guide thank you!
