Sony Xperia Z3 Dual Battery Replacement
Выберете то, что вам нужно
Видео обзор
  1. Sony Xperia Z3 Dual Battery Replacement, Battery: шаг 1, изображение 1 из 2 Sony Xperia Z3 Dual Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Heat the back cover to soften the adhesive sticker.
    • Use the suction cup to open a gap from top side or bottom side.
  2. Sony Xperia Z3 Dual Battery Replacement: шаг 2, изображение 1 из 3 Sony Xperia Z3 Dual Battery Replacement: шаг 2, изображение 2 из 3 Sony Xperia Z3 Dual Battery Replacement: шаг 2, изображение 3 из 3
    • Insert into the guitar pick and slide to cut the sticker.
    • Remove the back cover.
    In step 5 where it says that there is adhesive on the battery, my adhesive was actually joining the battery to the back plate making this step quite difficult. I had to focus the heat on the backplate right where the battery was and then use a long lever to separate the battery from the back plate.
    Seb Carroll - Ответить
  3. Sony Xperia Z3 Dual Battery Replacement: шаг 3, изображение 1 из 1
    • Release battery flex connector carefully to avoid breaking the pins.
  4. Sony Xperia Z3 Dual Battery Replacement: шаг 4, изображение 1 из 1
    • Get free that sticker which for fastening the battery.
  5. Sony Xperia Z3 Dual Battery Replacement: шаг 5, изображение 1 из 1
    • Pry up with a little effort because there is adhesive under the battery though not so strong.
  6. Sony Xperia Z3 Dual Battery Replacement: шаг 6, изображение 1 из 1
    • That's Sony Xperia Z3 Dual 3100mAh battery.
    • When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
Заключение
12 участников успешно повторили данное руководство.
Sophia
Участник с: 03/25/14
43 810 Репутация
Автор 62 руководств
2 Комментариев
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Victor Aguirre - Ответить
Just finished this guide thank you!
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 28,190
