Введение
This is the replace guide for Sony Xperia Z3 Dual as well as Sony Xperia Z3 earpiece speaker.
Выберете то, что вам нужно
Power off and remove two SIM card trays at first before earpiece speaker replacement.
Heat to soften back cover adhesive sticker.
Use suction cup to open a gap and insert into the guitar pick.
Slide guitar pick to cut the sticker.
Release all the connectors connecting with motherboard.
Pry motherboard up from left side. It's really hold tightly by some hidden keys, so be careful.
Remove motherboard.
Remove the blocker beside earpiece speaker and you can see the breakout to pry up the speaker.
Remove earpiece speaker finally.
13 участников успешно повторили данное руководство.
3 Комментариев
Thanks for the guide, it worked very well.
Maybe it's worth mentioning that there's a sticker at the back of the battery and you shouldn't be afraid to just pull the battery out.
