Введение
This is the replace guide for Sony Xperia Z3 Dual as well as Z3 loudspeaker assembly.
Video Overview
  1. Heat to soften back cover sticker. Place the suction cup and try to open a gap. Insert the guitar pick into the gap.
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Slide the guitar pick to cut the sticker and remove the back cover. Slide the guitar pick to cut the sticker and remove the back cover.
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Remove two screws by Philips screwdriver. Release all the connectors connecting with loudspeaker assembly. Remove the small vibrator securing bracket.
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it.
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Pry up the assembly and carry it out. Pry up the assembly and carry it out. Pry up the assembly and carry it out.
    • Pry up the assembly and carry it out.
  6. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
Заключение
4 участников успешно повторили данное руководство.
Sophia
Участник с: 25.03.2014
42 104 Репутация
Автор 62 руководств
Комментариев: 2
this is all good but is there a link to the part ?
morten hundevad - Ответить
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 7
За всё время: 3,969
