Введение
Use this guide to remove a broken or defective LCD & Digitizer in your Sony Xperia Z4.
Opening the Sony Xperia Z4 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water protection.
Due to the phone’s design, you must remove the lithium-ion battery to access the display cables. If the battery was deformed during removal replace it with a new one—reusing a deformed battery is a potential safety hazard.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom left corner.
Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
Use a pair of tweezers to carefully peel the adhesive strip off the mother board and the battery and remove it.
Use a pair of tweezers to peel the black adhesive strip off the battery connector and fold it out of the way.
Use a pair of tweezers and grab the pull tab at the top right corner of the battery.
Pull out the adhesive strip with a pair of tweezers.
Repeat the previous process with the adhesive tab next to the battery flex cable.
Use an opening pick to pry the battery out of its recess until you can get a good grip.
Use a pair of tweezers to peel off and remove the foam pad on top of the daughterboard.
Use the flat end of a spudger to pry up and disconnect the small main flex connector next to the vibration motor connector.
Lift the daughterboard cover using a pair of tweezers or a spudger by prying it up from its left side.
Remove the daughterboard cover carrying the daughterboard.
Use the flat end of a spudger to pry up and disconnect the main flex cable connector.
Use a pair of tweezers to pry up and disconnect the upper connector of the antenna cable.
Use a spudger to pry up and disconnect the main flex cable from the motherboard.
Insert one arm of the tweezer into the gaps between antenna cable routing and midframe.
Loosen the clips along the antenna cable on the right side of the midframe by gently twisting the tweezers sideways until the cable routing pops out of the clips.
Use a pair of tweezers to peel up the main flex cable and separate it from the midframe.
Use a pair of tweezers to remove the main flex cable assembly including the vibration motor and the microphone.
Unhook and remove the metal shield above the loudspeaker cover located at the bottom left.
Also remove the plastic safeguard between the midframe and the loudspeaker cover.
Use a pair of tweezers to pry up the loudspeaker cover.
Fold the loudspeaker cover upwards until you have enough space to remove the loudspeaker in the next step.
Use a pair of tweezers to lift the loudspeaker out of its recess and remove it.
Use a pair of blunt nose tweezers to grab the flex cable between the charging port and the loudspeaker cover.
Carefully pull the charging port out of its housing.
Use a spudger to pry up and disconnect the side button flex cable on the left side of the motherboard.
Use a pair of tweezers to loosen the plastic clips along the side button flex cable on the left side of the midframe.
Peel up the side button flex cable and separate it from the midframe.
Remove the side button flex cable including the loudspeaker cover and the charging port.
Use a pair of tweezers to unhook the metal shield on top of the display cable assembly and remove .
Use a pair of tweezers to peel off the black adhesive on the left side of the display cable assembly.
Also remove the silver adhesive strip on the right side of the display cable assembly.
Get an opening pick under the left side of the display cable assembly.
Use the opening pick to pry up the display cable assembly.
Carefully slide the opening pick from left to right to separate the display cable assembly from the midframe.
Apply a heated iOpener to the display for two minutes to loosen the adhesive beneath.
Apply a suction handle near the top edge of the phone right under the earpiece speaker.
Use the suction handle to pull up the screen and insert just the tip of an opening pick under the right edge of the speaker recess.
Slide the opening pick to the top right corner to loosen the adhesive.
Leave the opening pick in its position to prevent the adhesive from resealing.
Insert a second opening pick at the top right corner of the screen.
Slide the opening pick along the midframe to loosen the adhesive under the right edge of the screen.
Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
Insert a third opening pick under the bottom right edge of the screen.
Slide the opening pick to the bottom left corner to loosen the adhesive underneath the screen.
Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the bottom left edge of the screen.
Slide the opening pick along the midframe to loosen the adhesive under the left side of the screen.
Slide the opening pick around the top left corner of the screen to loosen the remaining adhesive.
Slowly separate the screen from the frame and cut any remaining adhesive. Make sure the flex cable is no longer stuck to the frame and carefully thread it through its gap.
Remove the screen.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
