Введение
This guides will show you how to replace the battery in your Sony Xperia Z5.
Выберете то, что вам нужно
Heat the back cover to soften the adhesive.
Place the suction cup and insert metal opening tool to open a gap from top side.
Insert the guitar picks and slide it to cut the adhesive underneath.
Remove back cover.
Release battery connector and pull off the adhesive tape underneath.
Pry up battery.
25 участников успешно повторили данное руководство.
7 Комментариев
worked a treat - simple straightforward - thanks!!
umm how do you put the cover back on?
Just push and then consolidate with heat, I used hair dryer.
