Выберете то, что вам нужно
Heat the back cover to soften the adhesive sticker.
Place the suction cup and inert metal opening tool to open a gap from top side.
Insert the guitar pick and slide it to cut the adhesive sticker underneath.
Remove back cover.
Release battery connector and pull off the adhesive tape underneath.
Pry up battery.
Release rear camera connector, front camera connector, audio jack flex connector and main flex connector on the motherboard and remove the screws there.
Take away the plastic bracket.
Remove metal cover securing loudspeaker and twist off screws.
Pry up and loosen the bottom side of main flex assembly.
Remove main flex. ( Attention: the fingerprint sensor connector is here, be careful to loosen it)
14 участников успешно повторили данное руководство.
