Введение
If the buttons are failing to work on your device, you should consider replacing the buttons. Use this guide to replace the buttons in your phone.
Выберете то, что вам нужно
Heat up the back cover to soften the adhesive.
Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
Remove back cover.
Release charging port connector.
Remove plastic protective bar.
Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
Push audio jack out of the slot, no adhesive underneath.
Release LCD flex connector and main flex connector. Use a small flat tool to flip up the white edge of the connector to release tension on the end of the flex cable. Then the flex cable should slide out without any resistance.
Separate motherboard assembly from middle housing.
Take away NFC antenna on battery.
Be aware that the NFC antenna is held by an adhesive and made of thin plastic. Remove it very carefully.
Release battery connector.
Pull straight out on the black ends of the battery adhesive strips until they come off.
Pry up and remove battery.
Place the new battery adhesive strips on the motherboard
Press the new battery in place
Follow all the steps in reverse to reassemble your phone
Use the tweezers to push the buttons from the outside to the inside of the phone.
Use the tweezers to gently remove from the connector.
