Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Here is the Sony Xperia Z5 front camera replacement guide.
  1. Heat the back cover to soften the adhesive sticker. Place the suction cup and inert metal opening tool to open a gap from top side.
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and inert metal opening tool to open a gap from top side.
  2. Insert the guitar pick and slide it to cut the adhesive sticker underneath. Remove back cover. Remove back cover.
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  3. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Release battery connector in order to prevent short circuit.
    • Release battery connector in order to prevent short circuit.
  5. Release audio jack flex connector and twist off the Phillips screws underneath. Remove the plastic bracket securing the front camera. Remove the plastic bracket securing the front camera.
    • Release audio jack flex connector and twist off the Phillips screws underneath.
    • Remove the plastic bracket securing the front camera.
  6. Release front camera connector and remove front camera. Release front camera connector and remove front camera. Release front camera connector and remove front camera.
    • Release front camera connector and remove front camera.
Заключение
Еще один человек закончил это руководство.
Lenka
Участник с: 06.11.2015
2 274 Репутация
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 1,317
