Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This video shows how to replace and reassemble Sony Xperia Z5 LCD display.
Выберете то, что вам нужно
Видео обзор
Heat the back cover to soften the adhesive sticker.
Place the suction cup and insert metal opening tool to open a gap from top side.
Insert the guitar pick and slide it to cut the adhesive sticker underneath.
Remove back cover.
Release battery connector.
Pull off the adhesive tape underneath the battery.
Pry up battery.
Release rear camera connector, front camera connector, audio jack connector and main flex connector on the motherboard.
Twist off screws there.
Remove that rubber securing bracket.
Remove metal cover and twist off two screws.
Loosen the bottom side of main flex assembly.
Loosen side button contactors ( Attention: the fingerprint sensor is here, be careful to loosen it), then remove the whole main flex assembly.
Release LCD screen flex connector, charging port connector, microphone connector here.
Remove motherboard.
The sticker underneath is strong, so use heat gun to soften it for a few minutes.
Remove LCD screen carefully.
46 участников успешно повторили данное руководство.
45 Комментариев
Awesome guide. Helped me alot. However i got blank screen after installing the new screen. Dont panic. You must replace the tape that covers the lcd filters. If you dont the metal plate will bridge the connections and the LCD will not display. I thought i broke the LCD however just replaced the tape off the original LCD and BOOM!
What are the filters? I have a repair shop and all screens are like these. Can't find them anywhere.
Johnny -
Hi, you need to reuse the black tape sticked on the original flex cable to cover the filters on the replacement part.
I would like also to know which tape you replaced.
Patrick -
What r the lcd filters as I have replaced a screen on Sony z5 on 2 phones now and the backlight isn't working on both phones but u can see that the screens r working any help would be great thanks
Barry -
