Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Press down the release button on the bottom left corner of the face plate.
Then remove the face plate carefully.
Инструмент, используемый на этом этапе:Phillips #0 Screwdriver$5.49-
Using the Phillips #0 Screwdriver, unscrew the 3 screws (length - 7.5mm) on the front of the device.
Инструмент, используемый на этом этапе:Phillips #1 Screwdriver$5.49-
Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
Remove side-metal plates gently.
Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
Lift off the top plate.
Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
Firmly grip the body of the stereo and pull off the silver back plate.
Using the Phillips #0 Screwdriver, unscrew the 4 dark-silver screws (length - 3.71mm).
Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
Remove the power supply on the circuit board. Please follow the iFixit soldering guide to assist you.
2 участников успешно повторили данное руководство.
