Введение
Use this guide to replace the battery in your Sony BDP-SX1000.
Выберете то, что вам нужно
Шаг 1 How To Open The Device
Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
Flip the Sony BDP-SX1000 over so that the underside is facing up.
Remove the four 2mm Phillips #0 screws at the top of the device.
Remove the rest of the J0mm Phillips #0 screws from the device.
Take out the seals at the bottom and at the corners with edge of screwdriver. Remove the J0mm Phillips #0 screws under the seals.
Remove the back lid of the Sony BDP-SX1000 so that you can now see the inside of the device. The two lids are attached by two wires. The small wire on right side of the top lid goes on right side of bottom lid or on the black connector. The big wire on left side of the top lid goes on left side of the bottom lid or on white connector.
The battery can be found at the bottom of the device.
Remove the battery by removing the white connector.
