Выберете то, что вам нужно
Place the projector upside-down to access the screws on the bottom.
Remove five 9mm long screws with a Phillips 1 screwdriver.
Place the projector right side up and lift the top panel up and put it to the side.
Remove five 9mm screws with a Phillips 1 screwdriver
Remove one 11mm screws with a Phillips one screwdriver
Remove all clips from mother board.
There are two additional clips underneath the mother board that need to be disconnected as well.
To remove the ribbon cables, lift up on the black hinge with a fingernail or the tip of your spudger.
Now, use a spudger or a barbecue skewer to lift the cable out.
Lift the board up slowly, making sure there are no snagged cables.
Unplug the two power cables coming into the board.
Remove the mother board from the device.
