Sophix TAB-730g Screen Replacement
Выберете то, что вам нужно
  1. Sophix TAB-730g Screen Replacement, Screen: шаг 1, изображение 1 из 1
    • Take off the screen protector and the screen on the tablet.
    • Wedge a plastic opening tool between the screen protector and the screen.
    • Using leverage, move the tool around the entire front face of the tablet in order to break the adhesion.
    • Continue until the top screen protector pops off.
  2. Sophix TAB-730g Screen Replacement: шаг 2, изображение 1 из 1
    • The screen is attached to a ribbon cable in the lower left hand corner marked in the picture (see highlighted area in picture).
    • The back cover of the device will need removed before continuing.
  3. Sophix TAB-730g Screen Replacement: шаг 3, изображение 1 из 1
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  4. Sophix TAB-730g Screen Replacement: шаг 4, изображение 1 из 1
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  5. Sophix TAB-730g Screen Replacement: шаг 5, изображение 1 из 1
    • Remove the tape covering the ribbon cable's (which connects to the front of the screen) insertion point on the back of the device.
    • This will allow you access to remove the ribbon cables that is hindering you from taking off the screen.
  6. Sophix TAB-730g Screen Replacement: шаг 6, изображение 1 из 1
    • Remove the ribbon cable by placing your fingers on the outside of the ribbon closest to the port it goes into.
    • Flip the black switch up so the ribbon cable will be able to come out.
    • Gently pull the ribbon cable out of the port.
Заключение
Еще один человек закончил это руководство.
JT Hiquet
Участник с: 09/29/16
333 Репутация
Автор 3 руководств
Команда
IUPUI, Team 2-3, Harley Fall 2016 Участник IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
4 членов
Автор 6 руководств
Один комментарий
Where to buy a replacement screen for a azpen A848 projector tablet
gayle almond - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 516
