Sophix TAB-730g Screen Replacement
Выберете то, что вам нужно
    1. Sophix TAB-730g Screen Replacement, Screen: шаг 1, изображение 1 из 1
      • Take off the screen protector and the screen on the tablet by using a spudger between the screen protector and the screen.
      • Using leverage, move the tool around the entire front face of the tablet in order to break the adhesion and continue until the top screen protector pops off.
      Спросите у FixBot
      Добавить комментарий
    2. Sophix TAB-730g Screen Replacement: шаг 2, изображение 1 из 1
      • The screen is attached to a ribbon cable in the lower left hand corner marked in the picture (see highlighted area in picture).
      • The back cover of the device will need to be removed before continuing.
      Спросите у FixBot
    3. Sophix TAB-730g Screen Replacement: шаг 3, изображение 1 из 1
      • Remove the back cover to gain access to the mother board.
      • Unscrew the 3.547 mm long screw, with a #000 Phillip's screwdriver, located at the bottom of your tablet.
      Спросите у FixBot
    4. Sophix TAB-730g Screen Replacement: шаг 4, изображение 1 из 1
      • Firmly, slide the cover away from the ports with your hand to remove the back cover.
      Спросите у FixBot
    5. Sophix TAB-730g Screen Replacement: шаг 5, изображение 1 из 1
      • Remove the tape covering the ribbon cable's (which connects to the front of the screen) insertion point on the back of the device.
      • This will allow you access to remove the ribbon cables that is hindering you from taking off the screen.
      Спросите у FixBot
    6. Sophix TAB-730g Screen Replacement: шаг 6, изображение 1 из 1
      • Remove the ribbon cable by placing your fingers on the outside of the ribbon closest to the port it goes into.
      • Flip the black switch up so the ribbon cable will be able to come out.
      • Gently pull the ribbon cable out of the port.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
JT Hiquet
Участник с: 09/29/16
333 Репутация
Автор 3 руководств
Команда
IUPUI, Team 2-3, Harley Fall 2016 Участник IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
4 членов
Автор 9 руководств
1 Комментарий к руководству
Where to buy a replacement screen for a azpen A848 projector tablet
gayle almond - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 29
За всё время: 869
