Sophix TAB-730g Speakers Replacement
Просмотр статистики:
За последние 24 часа:
За последние 7 дней:
19
За последние 30 дней:
88
За все время:
572
Комментарии: 0
Никто не оставлял комментариев к этой инструкции. Будете ли Вы первым?
Перейти к комментариям инструкции
Завершено: 0
Никто не отмечал эту инструкцию как "завершенное". Будете ли Вы первым?
Избранные: 0
Никто не добавил эту инструкцию в избранное (и не подписался на нее). Будете ли Вы первым?
Необходимое время: 30 минут
Сложность: Сложно
If the sound quality coming from your Sophix (730g) tablet is distorted, muffled, sporadic, or just doesn’t sound like it used to, there could be a problem with the tablet's speakers.
Before using this guide, first check to see that the volume control is set properly. An improperly set volume control may create a sound that is different than expected to be emitted from the tablet.
If that doesn’t fix the problem, check to make certain that there is no type of external material of any kind, such as tape, paper, fabric, or any other form of external obstruction that has become stuck or lodged in, on, or near the speakers.
If this does not fix the quality of sound, it could mean that there is some type of debris inside the small holes that has the speakers clogged. This can easily be cleared using a soft brush or cloth, or by blowing on the speakers using a can of compressed air or a small electronic dust blower.
 If none of these troubleshooting suggestions improve the sound quality emitted from your tablet it could mean that your speakers have gone bad. You can easily replace them yourself following the steps in this guide.
To complete this project, you will need to know how to use a solder iron. The project requires that one first desolder, then resolder specific parts of the tablet.
Before you begin, make sure that you have powered off the tablet and disconnected it from any electrical power source.
Begin with a clean, dry surface that is well-lit and free of debris. Plug in the solder iron so that it may begin heating.
Выберете то, что Вам нужно
Инструменты
    1. Sophix TAB-730g Speakers Replacement, Speakers: шаг 1, изображение 1 из 1
      • Remove the back panel of the tablet so that you can access the tablet’s motherboard.
      • First, using the #000 Phillips screwdriver, remove the screws located at the bottom of the tablet.
      Спросите у FixBot
      Добавить комментарий
    2. Sophix TAB-730g Speakers Replacement: шаг 2, изображение 1 из 1
      • After you have removed the screws from the bottom of the tablet, you can now slide the cover off. To do this, place your hand on the panel and firmly slide the panel in the direction that the arrow indicates.
      Спросите у FixBot
    3. Sophix TAB-730g Speakers Replacement: шаг 3, изображение 1 из 1
      • Next, find the wires that connect the speakers to the motherboard. (Follow the red marker indicated in the image.) To remove these, you will use the soldering iron.
      Спросите у FixBot
    4. Sophix TAB-730g Speakers Replacement: шаг 4, изображение 1 из 1
      • Turn the device so that the speakers are at the top.
      • Locate the leads that connect the logic board to the speakers.
      • Starting from the left, you will use the solder iron to desolder the first four leads.
      • Now you are ready to remove the old, and insert the new speakers.
      Спросите у FixBot
Заключение
JT Hiquet
Участник с: 09/29/16
333 Репутация
Автор 3 руководств
Команду
IUPUI, Team 2-3, Harley Fall 2016 Участник IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
4 членов
Автор 36 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 19
За последние 30 дней: 88
За все время: 572
