Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Usa questa guida per sostituire un pannello inferiore rigato, piegato o rotto sul tuo MacBook Pro 15" Retina Display versione metà 2015.
  1. Rimuovi le seguenti viti pentalobe P5 che tengono unita la parte inferiore del case al resto del MacBook Pro:
    • Rimuovi le seguenti viti pentalobe P5 che tengono unita la parte inferiore del case al resto del MacBook Pro:
    • Otto da 3,1 mm
    • Due da 2,3 mm
    The number of screws listed here is wrong on my model. I had four of the smaller size.
    anonymous 1286 - Ответить
    Just to add to my comment above (I can't edit it because it's anonymous), my MacBook Pro is a mid-2015 15in model 2.8GHz (A1398; EMC2881). For the bottom case it uses six 3.1mm screws, and four 2.3mm screws at the clutch/hinge side of the MacBook Pro. I tried using a 3.1mm screw at the clutch/hinge end, as described in the main article, and they don't fit. It has to be four 2.3mm screws.
    WAIT!.. STOP.
    iFixit has had a slew of defective batteries that they will require you take out and return (after gluing them in). Search on: "Battery percentage suddenly drops" here on this site. This process is 50 steps to get the new battery in, and another 50 to put all the parts back. For $199, Apple will do the whole repair, warranty it, and also replace the trackpad and the keyboard (because it's easier for THEM to do).
    Ifixit WILL NOT stand behind defective batteries unless you spend another 4-6 hours swapping in a new one. NOT. WORTH. IT. See posts here (Battery percentage suddenly drops from ~60% to 7%) on frustrated customer’s multiple attempts and class-action lawsuits.
    MFMauceri - Ответить
    Thank you for this info, you’ve probably saved a lot of time, and hassle (myself included, if I end up going through with this repair).
    Andrew Poindexter -
    The instructions below have you basically taking ALL of the guts out of case. I’ve been doing my own apple repairs since before ifixit was a thing and this one is a handful. My battery was swelling and I wanted to remove it before it burst or bent the case so I took it out without having a replacement and it occurs to me that aside from using the solvent (liquid) to remove the adhesive, you could probably do this only taking the trackpad ribbon out. I have mine reassembled now and will research the best battery to buy but I think installation will take about 5 minutes. See if you can slip a plastic gift card under the battery and wag/saw the adhesive out without the solvent before you go through all of this. It might work. Note, don’t bend or put too much stress on the battery and certainly don’t puncture it…
    br1ansk - Ответить
    I’m having a problem trying to get the screws off. I have a set of pentalobe screwdriver set. I found one screwdriver that fits perfectly on one set of screws, but I am unable to unscrew it. I tried using some force pushing the screwdriver into the screw, but nothing happens. Any suggestions?
    henry_k_wong - Ответить
    All the screws on mine are the same length for some reason.
    ccfman2004 - Ответить
  2. Sollevandolo delicatamente dal bordo vicino alla cover della frizone, alza dal MacBook Pro il case posteriore. Sollevandolo delicatamente dal bordo vicino alla cover della frizone, alza dal MacBook Pro il case posteriore.
    • Sollevandolo delicatamente dal bordo vicino alla cover della frizone, alza dal MacBook Pro il case posteriore.
  3. Il case inferiore è dotato di due perni di plastica (evidenziati con i rettangoli in rosso) che si inseriscono nelle clip sempre di plastica nella parte superiore del case (evidenziate nella foto con i rettangoli color arancione). Durante il riassemblaggio, spingi delicatamente verso il basso il centro del case inferiore per riattaccarlo alle due clip di plastica. Durante il riassemblaggio, spingi delicatamente verso il basso il centro del case inferiore per riattaccarlo alle due clip di plastica.
    • Il case inferiore è dotato di due perni di plastica (evidenziati con i rettangoli in rosso) che si inseriscono nelle clip sempre di plastica nella parte superiore del case (evidenziate nella foto con i rettangoli color arancione).
    • Durante il riassemblaggio, spingi delicatamente verso il basso il centro del case inferiore per riattaccarlo alle due clip di plastica.
    pretty hard to put it back, so I just remove the clips on the upper case....
    jamiegan835 - Ответить
    The trick to putting it back on is to guide your fingers to the same level as the clips, and then when you put the case down move your hand from the left side of the case to the right side of the case; applying pressure when you reach the area where the clips are.
    Aaron Freidus - Ответить
    You don't have to take so many steps.
    santa1234 - Ответить
    I have magnets- is this the wrong guide?
    Benjamin Jones - Ответить
Заключение
Per rimontare il tuo dispositivo, segui queste istruzioni in ordine inverso.
19 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Andrew Optimus Goldheart
Участник с: 17.10.2009
458 578 Репутация
Автор 410 руководств
Команда
iFixit Участник iFixit
Community
132 членов
Автор 12 990 руководств
Комментариев: 3
Do we need two different screw drivers for this or is the recommended one enough?
Jamey Rassweiler - Ответить
You need the recommended one for the lid an a torx T5 for the screws inside
Oros -
hello i have a 2015 15” macbook pro nut i want them all custom to me so scraped off the paint to be clear back. ive seen many “clear looking stickers but they mostly look $@$*!&. have you herd of any copany selling a clearback housing and can only find stickers do you knaw any sites delling vlear hpusings?. the only other thing i can think of if have a friend #D print in clear and polish it till turns clear any ideas? i also wany yje top case vlrar slso but oe thing at a time
jae.good - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 27
За последние 7 дней: 254
За последние 30 дней: 1,101
За всё время: 35,200
