Введение
Replacing the battery requires opening up the speaker and unscrewing the bottom and upper part of the speaker. You will need a Phillips screw driver, blue plastic opening tool and a new battery.
Выберете то, что вам нужно
Place the speaker on a flat surface.
Take your blue plastic opening tool and remove the outside cover.
Reorient the speaker so the black panel is facing up.
Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
Now remove the plate.
Reorient the speaker so the bottom is facing up.
Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
Now open the plate.
With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
Disconnect the battery wires from the circuit board.
Reorient the speaker so the back side is facing up.
Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
Loop the battery wires through the opening in the back plate.
The battery and it's connective wires have been completely removed from the speaker.
11 участников успешно повторили данное руководство.
9 Комментариев
Please provide the source to buy the replacement battery
They don't sell batteries!!
It says above that battery not for sale.
A simple online search and you will find the battery.
Can you also help me how to open the SB573 SOUNDBOT
Can you gets the mother board for this speaker
my soundbot was same design but different revision? (inside plastic was different, different compartment and different battery), still i had no problems following these same instructions
