Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Replacing the grille requires taking off the outside cover and unscrewing 14, 0.6cm screws. You will need a Phillips screwdriver, blue plastic opening tool and a new front metal cover.
  1. Before disassembling the speaker, make sure it is powered off.
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the plastic cover.
  2. Orient the speaker so that the top is facing up. Using your Phillips PH0 screwdriver unscrew the 14, 0.6cm screws from the device along the speaker grille. Using your Phillips PH0 screwdriver unscrew the 14, 0.6cm screws from the device along the speaker grille.
    • Orient the speaker so that the top is facing up.
    • Using your Phillips PH0 screwdriver unscrew the 14, 0.6cm screws from the device along the speaker grille.
  3. Reorient the speaker so the grille is facing you. Using the blue plastic opening tool, prop open the metal grille.
    • Reorient the speaker so the grille is facing you.
    • Using the blue plastic opening tool, prop open the metal grille.
    • Now the speaker grille is completely removed from the device and it can be replaced.
Заключение
Еще один человек закончил это руководство.
Yana
Участник с: 09.02.2016
492 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 2-50, Cagle Spring 2016 Участник USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 членов
Автор 2 руководств
Один комментарий
Sir my soundbot sb571 one side sound doesnot work how could i do for its repairing.
Ram Meena - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 1,269
