Sphero Ollie Battery Replacement
Выберете то, что вам нужно
  1. Sphero Ollie Battery Replacement, Tires and Hubcaps: шаг 1, изображение 1 из 1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Battery Replacement: шаг 2, изображение 1 из 2 Sphero Ollie Battery Replacement: шаг 2, изображение 2 из 2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Battery Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Battery Replacement: шаг 4, изображение 1 из 2 Sphero Ollie Battery Replacement: шаг 4, изображение 2 из 2
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Battery Replacement: шаг 5, изображение 1 из 2 Sphero Ollie Battery Replacement: шаг 5, изображение 2 из 2
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
  6. Sphero Ollie Battery Replacement, Battery: шаг 6, изображение 1 из 3 Sphero Ollie Battery Replacement, Battery: шаг 6, изображение 2 из 3 Sphero Ollie Battery Replacement, Battery: шаг 6, изображение 3 из 3
    • After you have removed the motherboard, use a JIS #1 screwdriver to remove the four 10mm Screws holding in the cog shields.
    • Next, you want to pull apart the clips (two on each side) holding the top piece of the shield to the frame.
    • Then, once you have freed the cogs, you can lift the cog and remove it from the frame.
    • To completely remove the cog shield out of the way, carefully remove the black pin connectors from the slot in the shield.
  7. Sphero Ollie Battery Replacement: шаг 7, изображение 1 из 2 Sphero Ollie Battery Replacement: шаг 7, изображение 2 из 2
    • Once you have removed the cog out of the way, you can then pinch the clip to access the battery.
    • To remove the battery, simply pull on it with slight force as it is held tight by adhesives.
Заключение
12 участников успешно повторили данное руководство.
Krystal Hedrick
Участник с: 10/30/17
361 Репутация
Автор 3 руководств
Команда
UW Tacoma, Team S1-G3, Rose Fall 2017 Участник UW Tacoma, Team S1-G3, Rose Fall 2017
UWT-ROSE-F17S1G3
4 членов
Автор 10 руководств
7 Комментариев
How do you buy a new battery, where do you get them from?
Alex - Ответить
Alex,
Amazon (Uxcell Power Supply DC 3.7 V 1000 MAh 803040 Li-ion rechargeable lithium Polymer Li- Po Battery
Keith Johnson -
Yes I need to find a battery as well
Keith Johnson - Ответить
Need a battery email me terrys2207@yahoo.co.uk
Terry Saunders - Ответить
Can I get a motherboard replaced in ollie. Please help me with reply to my email sgandham1980@icloud.com
gandham santhosh - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 30
За последние 30 дней: 88
За всё время: 7,658
