Введение
If Ollie's tires or hubcaps are damaged, worn out, or you just want an update, then try replacing them. This guide will walk you through how to replace the tires and hubcaps with only your hands and a Plastic Opening Tool!
Выберете то, что вам нужно
Firmly grasp Ollie in one hand.
Remove the blue rubber tire in a peeling motion with your opposite hand.
Continue to firmly hold Ollie in one hand.
Use a Plastic Opening Tool to gently pry off the hubcap.
2 участников успешно повторили данное руководство.
