Spigen Kuel TS36 Car Mount Spring Replacement
Выберете то, что вам нужно
  1. Spigen Kuel TS36 Car Mount Spring Replacement, Spring/coil: шаг 1, изображение 1 из 2 Spigen Kuel TS36 Car Mount Spring Replacement, Spring/coil: шаг 1, изображение 2 из 2
    • Pull the phone holder off the mount by applying force; the parts will not actually break from the pressure. Temporarily remove the two round half-socket covers on the ball socket, as they are prone to slipping off.
  2. Spigen Kuel TS36 Car Mount Spring Replacement: шаг 2, изображение 1 из 1
    • Remove four 5.0 mm screws from the backing panel of the phone holder using the Oval shape screwhead. Push out wing panels to release the mechanism, and remove the screws and holder from the backing panel.
  3. Spigen Kuel TS36 Car Mount Spring Replacement: шаг 3, изображение 1 из 2 Spigen Kuel TS36 Car Mount Spring Replacement: шаг 3, изображение 2 из 2
    • If either of the springs have not ejected from their slots, proceed to pull them out gently so that the chassis the wing panels are connected to remain undisturbed.
  4. Spigen Kuel TS36 Car Mount Spring Replacement: шаг 4, изображение 1 из 2 Spigen Kuel TS36 Car Mount Spring Replacement: шаг 4, изображение 2 из 2
    • Insert two new 2.6 cm springs as you would batteries to a tv remote. Be cautious as to keep the chassis in place during this process.
  5. Spigen Kuel TS36 Car Mount Spring Replacement: шаг 5, изображение 1 из 2 Spigen Kuel TS36 Car Mount Spring Replacement: шаг 5, изображение 2 из 2
    • Pull out of the wing panels to re-engage the mechanism, holding the center of panels down.
    • The backing panel will not be able to properly be reattached unless the mechanism is is engaged, and the springs are bunched.
  6. Spigen Kuel TS36 Car Mount Spring Replacement: шаг 6, изображение 1 из 2 Spigen Kuel TS36 Car Mount Spring Replacement: шаг 6, изображение 2 из 2
    • Slide the backing panel over the frame of the holder, aligning the sides. Press the button on the center of the holder to once again disengage the mechanism. This will allow the panel to fully slide back into place.
  7. Spigen Kuel TS36 Car Mount Spring Replacement: шаг 7, изображение 1 из 1
    • Rescrew backing with oval head screwdriver to reassemble the phone holder’s backing.
  8. Spigen Kuel TS36 Car Mount Spring Replacement: шаг 8, изображение 1 из 2 Spigen Kuel TS36 Car Mount Spring Replacement: шаг 8, изображение 2 из 2
    • With moderate to heavy force, apply pressure to the ball joint into the socket.
Заключение
Еще один человек закончил это руководство.
Ramy Huynh
Участник с: 09/30/19
172 Репутация
1 руководство автора
Команда
CSU Fullerton, Team S1-G1, Bruce Fall 2019 Участник CSU Fullerton, Team S1-G1, Bruce Fall 2019
CSUF-BRUCE-F19S1G1
4 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 26
За всё время: 1,018
