Введение
This guide will demonstrate how to properly replace the nose spring for the Hatchimal Draggle. The nose spring can be accessed by first removing the wings and fur .
Выберете то, что вам нужно
Use the spudger tool to push up on the black clip to free it.
Pull the clip out.
Lift fur up to reveal the next set of clips.
Insert a spudger to push up on the black clip to free it.
Pull out the clip.
Lift the fur up and over the Hatchimals Head.
Remove the six 12mm Phillips #00 screws from then body.
Remove the three 7mm Phillips #00 screws from the head.
Remove the wheel base and the circuit board carefully not to damage the spring.
Using the angled tweezers tool, disconnect the spring that is attached to the nose from the lever.
