Введение
Step by step instructional guide to replacing Spin Master Hatchimal Draggle speaker. Before getting started, fur and wing removal is required.
Выберете то, что вам нужно
Use the spudger tool to push up on the black clip to free it.
Pull the clip out.
Lift fur up to reveal the next set of clips.
Insert a spudger to push up on the black clip to free it.
Pull out the clip.
Lift the fur up and over the Hatchimals Head.
Remove the six 12mm Phillips #00 screws from then body.
Remove the three 7mm Phillips #00 screws from the head.
Remove the wheel base and the circuit board carefully not to damage the spring.
Gently pull the yellow speaker cord from circuit board. There will be little resistance.
Еще один человек закончил это руководство.
