Введение
Sometimes rough play can cause the wheel to break or not spin anymore. This guide will show you how to remove the wheel.
Выберете то, что вам нужно
Use the spudger tool to push up on the black clip to free it.
Pull the clip out.
Lift fur up to reveal the next set of clips.
Insert a spudger to push up on the black clip to free it.
Pull out the clip.
Lift the fur up and over the Hatchimals Head.
Remove the six 12mm Phillips #00 screws from then body.
Remove the three 7mm Phillips #00 screws from the head.
Remove the wheel base and the circuit board carefully not to damage the spring.
Remove the purple plastic casing. It should come off with little resistance.
Remove the wheel.
2 человек успешно провели ремонт по этому руководству.
