Введение
Most gravity flush toilets retain a small amount of water in the tank after draining. If there is still water in the bottom of your toilet tank after following our Draining a Toilet Tank guide, you may need to remove the excess water with a sponge.
Инструменты
Запчасти
Детали не указаны.
Use a sponge to soak up and remove any remaining water from the toilet tank.
Periodically squeeze the excess water from the sponge.
Еще один человек закончил это руководство.
