Введение
Many people have a sprinkler system and sprinkler heads tend to break occasionally. This guide will help people accomplish the task of replacing broken sprinkler heads themselves. Broken sprinkler heads can be diagnosed by the observance of poor water flow, incorrect water distribution or water shooting out like a geyser. By following the steps laid out in this guide, this project will reduce water usage and brown spots by assuring broken sprinkler heads are replaced properly.
Выберете то, что вам нужно
Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
Using your hand, screw the new sprinkler head on over the teflon tape.
Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
Enjoy your green lawn and water savings.
Еще один человек закончил это руководство.
