Выберете то, что вам нужно
Push the gray lever up towards the top of the phone.
Pull up on the battery pack and completely separate it from the phone.
Locate the five screws around the back casing.
Use a three-prong screw bit to remove all five screws.
Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
Use the plastic opening tool to remove the motherboard from the front case.
Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
Grasp the display on both sides and carefully pull the display off of the printed circuit board.
Using the plastic opening tool, carefully remove the yellow film covering the display connector.
Еще один человек закончил это руководство.
