Staples 34462 Electric Pencil Sharpener Cutter Replacement
Выберете то, что вам нужно
  1. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cover: шаг 1, изображение 1 из 1
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Cutter Replacement: шаг 2, изображение 1 из 1
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Cutter Replacement: шаг 3, изображение 1 из 1
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Cutter Replacement: шаг 4, изображение 1 из 1
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Cutter Replacement: шаг 5, изображение 1 из 1
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Cutter Replacement: шаг 6, изображение 1 из 1
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Cutter Replacement: шаг 7, изображение 1 из 1
    • Carefully pull the cover from the top panel and set it aside.
  8. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cutter: шаг 8, изображение 1 из 1
    • Orient the top panel so that the sensor bracket is facing you.
    • Using a Phillips00 screwdriver, remove four 10.42mm screws.
    • Using a Phillips00 screwdriver, remove two 6.96mm screws.
  9. Staples 34462 Electric Pencil Sharpener Cutter Replacement: шаг 9, изображение 1 из 1
    • Pull out the outside cover to remove it from the cutter chamber and set them side by side.
  10. Staples 34462 Electric Pencil Sharpener Cutter Replacement: шаг 10, изображение 1 из 1
    • Carefully pull the cutter out of the cutter chamber.
    • Beware of pencil shavings and debris.
Заключение
Еще один человек закончил это руководство.
Jen Hawkins
Участник с: 10/27/14
470 Репутация
Автор 4 руководств
Команда
Eastern Washington University, Team 1-5, Carnegie Fall 2014 Участник Eastern Washington University, Team 1-5, Carnegie Fall 2014
EWU-CARNEGIE-F14S1G5
7 членов
Автор 11 руководств
4 Комментариев
Very clear, easy to follow. Nice photos.
uccbill - Ответить
where can I get a replacement cutter?
Mel Buchanan - Ответить
Did you find replacement blades?
Horace M Hargroves -
Absolutely great directions. However I lost the two 10.3mm screws somewhere along the line - I did not go any further at that point. I will check out replacement cutters and see if I want to pursue or purchase new. I believe this was my work stapler of the 80's.
Leslie H - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 12
За последние 30 дней: 37
За всё время: 2,455
