Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your pencils are not properly sharpening, the problem could be a dull or worn cutter. This guide will show you how to replace the cutter component of your Staples 34462 Electric Pencil Sharpener.
Выберете то, что вам нужно
Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
Using the plastic opening tool, remove the back plastic feet.
After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
Orient the top panel so that the sensor bracket is facing you.
Using a Phillips00 screwdriver, remove four 10.42mm screws.
Using a Phillips00 screwdriver, remove two 6.96mm screws.
Pull out the outside cover to remove it from the cutter chamber and set them side by side.
Еще один человек закончил это руководство.
4 Комментариев
where can I get a replacement cutter?
Did you find replacement blades?
