Staples 34462 Electric Pencil Sharpener Gears Replacement
Выберете то, что вам нужно
  1. Staples 34462 Electric Pencil Sharpener Gears Replacement, Cover: шаг 1, изображение 1 из 1
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 2, изображение 1 из 1
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 3, изображение 1 из 1
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 4, изображение 1 из 1
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 5, изображение 1 из 1
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 6, изображение 1 из 1
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 7, изображение 1 из 1
    • Carefully pull the cover from the top panel and set it aside.
  8. Staples 34462 Electric Pencil Sharpener Gears Replacement, Gears: шаг 8, изображение 1 из 1
    • Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
  9. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 9, изображение 1 из 1
    • Carefully pull apart the gear housing's panels.
    • The gears are lubricated by petroleum jelly.
  10. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 10, изображение 1 из 1
    • Gently pry the first gear out of the gear housing with a spudger.
    • To ease reassembly, note the orientation of the gear as you pry it free.
  11. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 11, изображение 1 из 1
    • Gently pry the second gear out of the gear housing with a spudger.
    • To ease reassembly, note the orientation of the gear before you pry it free.
  12. Staples 34462 Electric Pencil Sharpener Gears Replacement: шаг 12, изображение 1 из 1
    • Gently pry the third gear out of the housing with a spudger.
Заключение
Еще один человек закончил это руководство.
Brian Eliason
Участник с: 10/27/14
379 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team 1-5, Carnegie Fall 2014 Участник Eastern Washington University, Team 1-5, Carnegie Fall 2014
EWU-CARNEGIE-F14S1G5
7 членов
Автор 11 руководств
Один комментарий
What about gears? Where do you get them? Mine just needs the gear from step 12 replaced.
krzynka - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 36
За всё время: 3,107
