Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your sharpener is making a loud grinding noise or the electric motor is running but the cutter is not rotating, then follow these steps to replace the gears in your Staples 34462 Electric Pencil Sharpener.
Выберете то, что вам нужно
Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
Using the plastic opening tool, remove the back plastic feet.
After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
Еще один человек закончил это руководство.
