Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
Using the plastic opening tool, remove the back plastic feet.
After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
Carefully pull the cover from the top panel and set it aside.
Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
Gently pry the first gear out of the gear housing with a spudger.
Gently pry the second gear out of the gear housing with a spudger.
Gently pry the third gear out of the housing with a spudger.
Еще один человек закончил это руководство.
