Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Steam Deck, воспользуйтесь нашим сервисным руководством.
  1. Steam Deck Chip ID, Side 1: шаг 1, изображение 1 из 2 Steam Deck Chip ID, Side 1: шаг 1, изображение 2 из 2
    • IC Identification, Pt. 1:
    • AMD/Valve 100-000000405 Quad-Core Application Processor w/ GPU
    • Micron MT62F1G32D4DR-031 WT:B 4 GB LPDDR5 SDRAM Memory
    • Winbond W25Q128JW 16 MB Serial NOR FLASH Memory
    • Analogix ANX7580 DisplayPort to Single MIPI Receiver
    • Cirrus Logic CS35L41B Audio Amplifier
    • Maxim Integrated MAX77961 USB Type-C Li-Ion Battery Charger
    • O2Micro OZ536 Backlight LED Driver
  2. Steam Deck Chip ID: шаг 2, изображение 1 из 1
    • IC Identification, Pt. 2:
    • Monolithic Power Systems MP2845 Digital 6-Phase Controller
    • Monolithic Power Systems MP86902B 35 A Power Stage
    • Monolithic Power Systems MP86903C Power Stage
    • Likely Monolithic Power Systems NB688C Synchronous Buck Converter
    • Monolithic Power Systems NB691 Synchronous Buck Converter
    • Monolithic Power Systems NB690G Synchronous Buck Converter
    • Possibly Monolithic Power Systems NB591 Synchronous Buck Converter
  3. Steam Deck Chip ID, Side 2: шаг 3, изображение 1 из 2 Steam Deck Chip ID, Side 2: шаг 3, изображение 2 из 2
    • IC Identification:
    • ITE Tech IT5570VG Embedded Controller (likely)
    • O2Micro OZ711 Card Reader Controller
    • Maxim Integrated MAX77958 USB Type-C & USB Power Delivery Controller
    • Diodes Incorporated PI3USB102 USB 2.0 SPDT Analog Switch
    • Texas Instruments TPS22976 Load Switch
21 Комментариев
Interesting how Valve went with a full-custom APU from AMD. I thought they’d use an off-the-shelf chip like the 4500U.
Ethan Zuo - Ответить
Yeah i know what you mean!
They most likely they where wanting it to not be that thick,
so not like a laptop or desktop CPU for it,
Due to it being kinda thick!
Ben Capehart -
I assume the only major difference between this and an off the shelf APU is that this APU just has everything the steam deck does not utilize disabled or removed for power consumption reasons. I doubt it goes much deeper than that.
Alyx -
Good Point
See what you mean
Ben Capehart -
The 4500u has 6 EC Vega GPU, while the Steameck APU has an 8 ECU RDNA 2 GPU. Plus the custom APU gives them more control than a OTS apu.
MJ26 Gaming -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 52
За последние 7 дней: 339
За последние 30 дней: 1,766
За всё время: 46,548
